My coil is just a big clump of rust, i decided to replace it with one from Rock Auto, it was supposed to fit (KEM). First thing i noticed it was about 1/3 the size of the one on my car now. The clamp will not close down enough and allow the mounting bolts to attach to the wheel well. Where can i get one that i will be sure will fit :disappoin
https://www.classiczcars.com/forums/topic/37478-coil-replacement/
Avoid KEM like the plague.
Had many a bad experience with them, especially electrical parts.
Fuel pumps, ignition modules and throttle position sensors were the 3 things I wound up replacing at least once within 6 mos of initial install.
Swore off them for good after the 2nd TPS.
http://www.classiczcars.com/forums/showthread.php?t=18413&highlight=kem
Edited by mlc240z
