No side marker lights
mbarjbar
  • 3 months later...
Can someone please verify this?
I was wet sanding the car yesterday, so I took off the rear passenger side marker light. After putting it back I had no rear lights, brake lights, nor rear side marker lights. After messing with the light a bit and re-establishing a ground, all the lights came back on.
So the question is, are all these lights SUPPOSED to be reliant on the ground of one side marker light in order to function? If so, that had better be a pretty good connection.
OK, so I think I can further refine my question here. The light circuit does indeed need to be grounded, just not at the point where the light screws into the body. The wiring diagram shows a ground somewhere near the RIGHT rear sidelight marker, but I can't find this on the body (I have the vapor recovery tank out). Does anyone know where that point is?
  • Who's Online   1 Member, 0 Anonymous, 714 Guests (See full list)
