November 28, 201014 yr comment_337197 That metal and plastic is your horn. Pop the horn button off, down at the bottom will be a screw holding the other broken part, (hopefully). It can be glued, I used super glue. If it needs to be adjusted to operate, the metal tang can be bent, but is very springy. The end of the brass tang needs to ride on the brass ring, but not too tight as to wear it out. Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/37534-dude-wheres-my-headlights-and-wires/?&page=3#findComment-337197 Share on other sites More sharing options...
December 1, 201014 yr Author comment_337523 got the dangling horn piece glued back together and screwed in place. Now the headlights....I am thinking the headlight combo is worn out. When I rotate the switch to headlights they don't turn on....when I give it a bit of extra force past the stop they turn on. Then go off when I release the pressure. Fixable or replace? Link to comment https://www.classiczcars.com/forums/topic/37534-dude-wheres-my-headlights-and-wires/?&page=3#findComment-337523 Share on other sites More sharing options...
December 1, 201014 yr comment_337524 Three options1 - Tear it apart & clean it yourself.2 - Contact Dave Irwin (Zs-ondabrain) and send it off to him to tear apart and clean.3 - Go to Rockauto.com and buy a new switch. It's less than $200. Link to comment https://www.classiczcars.com/forums/topic/37534-dude-wheres-my-headlights-and-wires/?&page=3#findComment-337524 Share on other sites More sharing options...
December 1, 201014 yr comment_337528 I'd take it apart and clean it, and make any needed repairs. You know it work, the contact may be louse or the corrosion is block contact with out seeing it that would be my guess. Link to comment https://www.classiczcars.com/forums/topic/37534-dude-wheres-my-headlights-and-wires/?&page=3#findComment-337528 Share on other sites More sharing options...
