Posted November 1, 201014 yr comment_334831 Just started a restoration on my 78 280 that was been up on blocks for several years. Need to rebuild the clutch hydraulics which is in progress but tried to manually cycle the clutch fork while the slaved cylinder is off to see if the throwout bearing is frozen. Anybody have any idea how much force on the end of the fork to move the throwout bearing. I tied probably around 30 pounds using a long pole from under the front of the car with no luck. Didn't want to bend anything internal.Thanks in advance Link to comment https://www.classiczcars.com/forums/topic/37543-clutch-fork-pressure-needed/ Share on other sites More sharing options...
March 16, 201114 yr comment_349410 Hello, The trouble with the older mechaincal linkage is wear in all the parts involved. This includes the pedal assembly wearing out the support bushing and into the steel support. This is a part often overlooked as it's up inside the dash, it has pot metal bushings that wear out over time. Make sure all the parts involved are fresh and tight.good luck!!________________ottawa used car Link to comment https://www.classiczcars.com/forums/topic/37543-clutch-fork-pressure-needed/#findComment-349410 Share on other sites More sharing options...
