Posted November 3, 201014 yr comment_334998 Hi, the driver's seat in my 1973 240z is broken. The back is still attached to the seat bottom, but it does not stay upright, so in other words its not locking in place. I don't want to buy a new seat as I don't have the cash, so what could be the problem, and is it easily fixable? I was thinking it could be the hinges attaching the back, but all i can find is hinges for a 280zx seat. Any help is appreciated! Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/ Share on other sites More sharing options...
November 3, 201014 yr comment_335015 I bet you could easily find a used seat. Many people replace the original seats and they are very willing to unload their OEM seat(s). Check over at hybridz.com where that mod is very popular. Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335015 Share on other sites More sharing options...
November 4, 201014 yr Author comment_335098 Im on a super tight budget so I think im gonna have to stick with the seat i have. I took a closer inspection today and it turns out that the bottom part of the seat frame is snapped on one side. Would jb weld work to fix it? thanks for the help and advice! Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335098 Share on other sites More sharing options...
November 4, 201014 yr comment_335110 Yoshi...Take the broken part to a local welding shop. They will be able to fix it up for just a few bucks.... and it will stay fixed. JB Weld isn't designed for structural use, so don't use it for that purpose. Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335110 Share on other sites More sharing options...
November 4, 201014 yr Author comment_335130 O ok, thanks! I will definitely do that then. You kno about what the cost might be? Its all good if you don't, I really appreciate the help! Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335130 Share on other sites More sharing options...
November 4, 201014 yr comment_335139 I'd think you could get it rewelded for about $20 - $40 here in Houston. Can't speak for the "city by the bay." Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335139 Share on other sites More sharing options...
November 4, 201014 yr comment_335148 I paid $5 at the local muffler shop to have mine welded. They are used to welding thin metal and can knock it out while you watch. Just remove the seat back and all the upholstery and padding before you take it to be welded. Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335148 Share on other sites More sharing options...
November 5, 201014 yr Author comment_335244 Oh ok, that sounds good! Would I have to remove the black paint from the seat frame first before bringing it in for welding? thanks! Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335244 Share on other sites More sharing options...
November 8, 201014 yr comment_335465 I did not remove the paint, they were able to weld it as is. I shot a bit of paint on if before putting it back together. Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335465 Share on other sites More sharing options...
November 9, 201014 yr Author comment_335551 o ok, sounds good, thanks! Link to comment https://www.classiczcars.com/forums/topic/37560-stock-seat-broken-is-a-repair-possible/#findComment-335551 Share on other sites More sharing options...
