Posted November 10, 201014 yr comment_335628 Someone link it for us......Looks like a great resto project, and an 11/69 build date !Item # 120644876035 Edited November 10, 201014 yr by Unkle Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/ Share on other sites More sharing options...
November 10, 201014 yr comment_335630 Here ya go....http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120644876035&ru=http%3A%2F%2Fmotors.shop.ebay.com%3A80%2F__%3F_from%3DR40%26_trksid%3Dm39%26_nkw%3D120644876035%26_fvi%3D1&_rdc=1 Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-335630 Share on other sites More sharing options...
November 10, 201014 yr comment_335631 Man it sucks to be poor! Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-335631 Share on other sites More sharing options...
November 11, 201014 yr comment_335671 Just for clarification that is HLS30-00231 and it has been listed on ebay and discussed here a few times. Here are a couple of old threads:http://www.classiczcars.com/forums/showthread.php?t=37252http://www.classiczcars.com/forums/showthread.php?t=39866-Mike Edited November 11, 201014 yr by Mike B Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-335671 Share on other sites More sharing options...
February 15, 201114 yr comment_346034 it's in my Garage now in United Arab Emirates... Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-346034 Share on other sites More sharing options...
February 15, 201114 yr comment_346045 Congrats on your new Z! What are your plans for it? Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-346045 Share on other sites More sharing options...
February 15, 201114 yr comment_346046 Yea, I was just reading this thread. Congrats! Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-346046 Share on other sites More sharing options...
February 16, 201114 yr comment_346139 Congrats on your new Z! What are your plans for it?thank you buddy.now it's under restoration process , I’ll remove all rust spots and change whatever needs to be changed from rubbers, bushings and parts.then i would remove the rims and install the "D" emblem hubcaps.Yea, I was just reading this thread. Congrats!thank you mate.---------------------------------------I would like to have your opinions about the engine , shall i keep the original engine or to install “L28 with triple mikuni carb “(probably i prefer to keep the original one)your thoughts guys is highly appreciated ...regards, Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-346139 Share on other sites More sharing options...
February 16, 201114 yr comment_346141 Pictures of the progress would be great! Good luck on the project, and enjoy the Z!If the engine block matches the ID plate, then keep it original...or at least keep the parts. If the numbers don't match, then build whatever engine you like. Edited February 16, 201114 yr by cygnusx1 Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-346141 Share on other sites More sharing options...
February 16, 201114 yr comment_346144 As I recall from the ebay ads, the original engine was seized. Did you get that engine shipped with the car? If so, you should at least try to get it rebuilt, even if you run another engine in the car. Not having the working original engine will definitely decrease the value of the car.-Mike Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-346144 Share on other sites More sharing options...
February 16, 201114 yr comment_346159 Pictures of the progress would be great! Good luck on the project, and enjoy the Z!If the engine block matches the ID plate, then keep it original...or at least keep the parts. If the numbers don't match, then build whatever engine you like. I got it with the original engine but unfortunately i couldn't find engine tag "ID Plate" to match the serial number. any other solutions to solve this matter? ! As I recall from the ebay ads, the original engine was seized. Did you get that engine shipped with the car? If so, you should at least try to get it rebuilt, even if you run another engine in the car. Not having the working original engine will definitely decrease the value of the car.-Mike the engine was shipped with the car ,but what I've understood from eBay's ads that the Piston kit "to rebuilt the engine" was seized. nice to chat with u mike , you are a 240Z Guru -Ismail Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-346159 Share on other sites More sharing options...
February 16, 201114 yr comment_346161 I got it with the original engine but unfortunately i couldn't find engine tag "ID Plate" to match the serial number.any other solutions to solve this matter? !Hello Ismail:What is the number on the engine you received? It should be stamped on the block just below the #5 and #6 spark plugs.?You can order a new Engine I.D. plate - see item number ID-O1 here: http://www.zzxdatsun.com/catDecals.phpIf you went to the trouble to find/buy a low VIN, 69 production Datsun 240Z - then it only makes sense to keep the original engine in it.good luck with the restoration...FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/37630-vin-231-on-ebay/#findComment-346161 Share on other sites More sharing options...
