Are door from 240s, 260s and 280s not interchangeable? Is the only difference the mounting for the inside door panel and handle?
The answer to that is definitely, "It depends."
A 2+2 door won't work on a couple and vice versa. Also later 280Zs (I think the 77 & 78...) have different latches from earlier doors.
  • 2 years later...
That is what happens when everyone is told to use the "Search" function - LOL
What is the Build Date on your 260Z? - I think the early 260Z's doors are the same as the 240Z doors - but the late year 260Z's that had the 280Z body were different.
Location Location Location..???
FWIW,
Carl B.
