Posted November 15, 201014 yr comment_336061 please i need a pic of the ignition and wires connected to it for 71 240z, i am putting everything back together but do not remember what wires go to the ignition. a picture would help .thanks carl h Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/ Share on other sites More sharing options...
November 16, 201014 yr comment_336071 Try downloading the wiring diagram from xenons30.comThat should help. Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336071 Share on other sites More sharing options...
November 16, 201014 yr Author comment_336110 a picture will help only Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336110 Share on other sites More sharing options...
November 16, 201014 yr comment_336132 Believe it or not, the FSM has pictures too. Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336132 Share on other sites More sharing options...
November 16, 201014 yr comment_336149 FSM pictures suck for proper detail. Do you need the coil area, the distributor, or both? Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336149 Share on other sites More sharing options...
November 16, 201014 yr Author comment_336178 steering column area wires behind the ignition Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336178 Share on other sites More sharing options...
November 16, 201014 yr comment_336181 Are you referring to the ignition switch or all of the wiring harness on the steering column? Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336181 Share on other sites More sharing options...
November 16, 201014 yr comment_336187 The wiring at the steering column is very straightforward... IF the connectors are still attached to the wires.Maybe I'm reading more into this than is there, but if you're needing a pictorial on the wiring in that area, my thoughts are that the wires have either been cut, or somehow you've lost all the connections/connectors.It may be simpler for YOU to post a picture of the wiring as YOU have it, and let us take a crack at helping you than your trying to figure out the wiring by looking at pictures that may not show the detail you will need.2¢E Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336187 Share on other sites More sharing options...
November 17, 201014 yr Author comment_336210 you are right i have connected all dash wiring and there is nothing left to connect to the ignition can remember if there was aseperate wire that is why i am asking for someone to show me a pic of the ignition wiring .thanks carl h Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336210 Share on other sites More sharing options...
November 17, 201014 yr comment_336211 OK, that's tougher. First, I'd need to pull the column cover of, then try to get my honking big camera back in there to try to take a meaningful picture.But this is really pretty simple, as the ignition switch/lock only has one large connector (5 pin), and two small wires (generally red w/blue trace) for the key-in-the-ignition squealer. There's really nothing else to it, and not much that you can mess up. Edited November 17, 201014 yr by Arne Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336211 Share on other sites More sharing options...
November 17, 201014 yr comment_336213 Pictures of an ignition lock/switch from a 4/71 build 240Z. Is the same as for my 7/71 as well. Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336213 Share on other sites More sharing options...
November 17, 201014 yr comment_336221 This is from the 73 FSM. Chances are that your wire colors are the same.Expect a six wire plug with five wires and the following colors:Black with Yellow stripeBlack with White stripeWhite with Red stripeBlue with Red stripeGreen with White stripeThere should be two other wires, one with a male spade and another with a female spade. One of those wires is red.Download a copy of the FSM and look at the Instrument Harness page in section BE for details on the plug. Link to comment https://www.classiczcars.com/forums/topic/37682-ignition-wires-to-a-71-240z/#findComment-336221 Share on other sites More sharing options...
