Posted November 15, 201014 yr comment_336062 is there an adjustment that can be made or a different switch to buy? I'm new to this car so be easy on me Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/ Share on other sites More sharing options...
November 16, 201014 yr comment_336074 Operates the same, uses the same two wires on the right side of the tranny.Are you having trouble? Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-336074 Share on other sites More sharing options...
November 17, 201014 yr comment_336207 FrankenScamp said: is there an adjustment that can be made or a different switch to buy?I'm new to this car so be easy on me They are the same thing. Now location of the threded hole on the bell housing for the switch is different depending on which 4 speed or 5 speed trans come from. :classic: Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-336207 Share on other sites More sharing options...
January 12, 201114 yr Author comment_341725 Quote Are you having trouble?Well, my reverse light come on in 4th gear. I read another post about this but it ended saying to adjust it or replace it. They didn't mention how the adjustment was made, figure it just screws straight in. Any help would b great.... Thanks Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341725 Share on other sites More sharing options...
January 12, 201114 yr comment_341728 dumb question, and I'm full of them this week, but are ya sure you got the right hole?Like I said, it's a dumb question but I gotta ask. You're right, they typically screw right in. I was unaware of an adjustability.that's weird,Dave Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341728 Share on other sites More sharing options...
January 12, 201114 yr Author comment_341730 I wasn't real clear about my issues in the first place, so no dumb ?'s. I've obtained a replacement switch but have yet to get the car up on jack stands to replace it. I was just making sure there wasnt some magic adjustment that I needed to make instead of just swapin old for new. Thanks for the speedy response!.... I'll let u know what I find. Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341730 Share on other sites More sharing options...
January 12, 201114 yr comment_341766 As Dave alluded to above, when I installed my 5 speed, I noticed a second hole, farther back than the one on the 4 speed. I just put the switch in the same hole location as that from the 4 speed (forward hole) and haven't had any problems. I'm not sure what the second hole is for. Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341766 Share on other sites More sharing options...
January 12, 201114 yr comment_341787 Mine was a dumb question, not yours. That's why I said "I'm full of them this week"Let us know Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341787 Share on other sites More sharing options...
January 12, 201114 yr Author comment_341814 All good. I knew what u were saying. Again, I wasn't real clear on my situation at first anyway. Cheers Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341814 Share on other sites More sharing options...
January 12, 201114 yr comment_341816 The later five speeds have switches that operate the spark timing control in 4th and 5th gear. If you hook the reverse light leads up to one of those, that would cause the reverse lights to come on in the corresponding gear. Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341816 Share on other sites More sharing options...
January 13, 201114 yr comment_341835 See? I knew it was something weird like that. Thanks for the insite.Dave Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341835 Share on other sites More sharing options...
January 13, 201114 yr comment_341942 sblake01 said: The later five speeds have switches that operate the spark timing control in 4th and 5th gear. So, just out of curiousity, what did that do? Was it to retard timing in the higher gears? Link to comment https://www.classiczcars.com/forums/topic/37683-reverse-light-switch-4spd-to-5-spd/#findComment-341942 Share on other sites More sharing options...
