Thank you Webdog and jaroberts! This will work. Pictures are always great, I'll post some when I get my dash together. I think that I will do the Shop-Vac hose and insulate it prior to install.
Might also consider the following source for hose from McMaster-Carr. Depending on the hose you select the temperature rating would be a lot higher...(I.E. - -65 to +300 F)
http://www.mcmaster.com/#catalog/116/210/=9uekxk
webdawg1
I bought replacement duct hose from Nostalgic Air. The 2" fits the eyeball ducts on the dash ends. I used a large plastic zip tie (ty-rap) to secure the hose on each end. The hose is very flexible and is double walled, so I'm not too concerned about insulating it.
http://www.nostalgicairparts.com/ac/duct-hose-sold-by-the-foot-76.php
  • 2 months later...
