I am looking to purchase 15x7 rota royal silver wheels for my 78 280..just wanting to know if anyone had any issues with center caps or clearence issues. Wanting to use 195/65/15 toyo tires..
Suspension is stock.. Any suggestions on offset... Thanks for any help..
https://www.classiczcars.com/forums/topic/37715-15x7-rb-rota-wheels/
Hi Scott, See my pm. 195-65/15s are too small. Your speedo will read fast and the tires will look small to you, also. They will look stretched on a 7" rim. A 215-60/15 will be almost the same diameter as the original 195-70/14s. I went with 205/60-15s due to valance clearance issues, and am happy with the results...my speedo reads a bit fast. Just my 2 cents.
Cheers, Mike
FWIW, I went with a 195-60/15 on my 15x7 Rewinds. I feel they do look a little stretched in width. When I buy new tires I'll probably go up a few sizes and get the clearance issues taken care of.
I do have some in 15x7 with ET04 on my lowered 240z.
I have 225/50-15 G-sport BFGoodridge tires. They fit. I only have 1/2" on each side of the tire of clearance between strut on one side and fender on the other...
No problem with center cap either ;)
I have a set of Rota RB wheels on my 71. 15x7 +04 offset. 205/55/15 tires. No issues with center cap or rubbing. I also have tokico springs/struts and I haven't had any issues.
Edited by AlexS13
  • 3 weeks later...
Thanks for everyones help.. I have dicided on 205/60/15 bridgestone
pole position tires..looks like they are the same size as the 195/70/14's i have now..same diameter..
Edited by scotts pearl
