I'm looking for the fake wood steering wheel and hornpad. I don't mind stripping the center of the wheel and repainting it if it needs it, but I'd like to get a hornpad without cracks in the back. Email me your asking price or post it here.
Dwight
https://www.classiczcars.com/forums/topic/3773-steering-wood-and-hornpad/
Thanks Owen, sent you a PM.:geek:
I'm now on the hunt for the horn pad (the one that says Datsun). Let me know who has one to get rid of on the cheap ROFL
Dwight
p.s. I'm surprised I have't gotten any smart alleck comments regarding the "steering wood" title in the first post.
If you do you'll give yourself tons of grief later.
If the back plastic insert, which fits on the horn switch mechanism is cracked, use JB Weld to fill in any gaps. You can also use a couple of those plastic wire ties on the outside of the plastic, but still inside the foam of the pad, to make it tight. Let it sit over night (at least). Then with a Dremel grind / sand smooth and then you can put it on as it is supposed to be.
I've personally done this and it does work.
Enrique
