strange problem
hazrider
If it's a manual transmission car, the only way for it to slow down without losing rpm is clutch slipping. Smoke and/or a nasty smell coming from the car when it happens would be a confirming sign.
If an automatic, I believe that bad clutches and/or a bad torque converter could allow the car to slow down without a change in rpm. Burnt transmission fluid would be a sign.
If you cruise down the highway in your top gear and then floorboard the accelerator pedal, does the engine RPM increase without the car going any faster? If so, then your clutch is slipping and would need rebuilding. Otherwise, there's no way for a car with a manual transmission (in gear) to slow down without the RPMs dropping.
When you say "start to" slow down, do you mean that you don't really lose speed (at least not enough to see on your speedometer), but you just momentarily lose a bit of power? If so, it could be any number of engine problems. It would be hard to be any more specific than that.
