Posted November 25, 201014 yr comment_336886 Hey guysI'm finally getting my heater core hooked up. Can some one confirm for me that the lower hose is the intake (the longer hose) and the upper is the return (the one that goes to the block) on a 280z. I just need to know prior to hook up. Jan Link to comment https://www.classiczcars.com/forums/topic/37775-heater-hook-up/ Share on other sites More sharing options...
November 25, 201014 yr comment_336894 You would be correct sir...see picture attached...picture is from from a 76 280Z (Reference pictures libarary) Memory has a bad habit of fading over time :tapemouth...so always good to find reference pictures to refer to down the road... webdawg1 Link to comment https://www.classiczcars.com/forums/topic/37775-heater-hook-up/#findComment-336894 Share on other sites More sharing options...
