Alignment question
mlaw7
Just had NTB check the alignment this afternoon on my '78.
The front looks great, only required a minor adjustment to the passenger side toe. However, the rear wheels are a bit out of spec. I know there's no factory adjustment for the rear, and from what I understand the only adjustment possible is a camber kit.
Following are the specs on my rear wheels. Can any of you tire/suspension gurus interpret and/or comment on them?
Rear left:
Camber: -0.3 Specified Range: -0.1 to 1.5
Toe: 0.44 Specified Range: -0.22 to 0.22
Rear right:
Camber: -0.4 Specified Range: -0.1 to 1.5
Toe: 0.24 Specified Range: -0.22 to 0.22
Cross camber: 0.1
Total toe: 0.68 Specified Range: -0.44 to 0.44
Thrust angle: 0.10
Thanks!
