I'm sure it's in this thread somewhere, but I didn't see it.  What's the total number of dash light bulbs needed for the speedo, tach, and three center gauges?  I am going to place an Amazon order for the BA9s bulbs. I'm less worried about the ash tray, glove box, and other misc bulbs right now.
Thanks!
Got some more pics of my gauges and other lights inside the cabin.  Again, all the following pictures have been shot in manual exposure mode with a white balance set at 5000K.
Here’s a pic of the three small gauges with bulb number 6 from my previous post.
Here’s a pic of the speedo and tach.
I also put LED bulbs in the turn signal indicators, high beam indicator, and brake warning light in the gauges.  I tried a couple different bulbs but forgot to take before and after pictures.  These are what I used.
For the turn signals I got green bulbs from superbrightleds.com.
https://www.superbrightleds.com/moreinfo/ba9s-ba7s/ba9s-led-bulb-1-led-ba9s-retrofit-car/3/#/attributes/15
Green. 90°. 4 Lumens.       BA9s
These bulbs are perfect.  Obviously brighter than the stock tungsten bulb, but not overpowering.
Got a red bulb of the same variety for the brake warning light and the fuel warning light.  Again, brighter then stock but not too much.
For the high beam indicator I went with a different style bulb then the turn signal lights and brake light.
https://www.superbrightleds.com/moreinfo/ba9s-ba7s/ba9s-led-bulb-4-led-ba9s-retrofit-car-classic-car-bulbs/6/
Here’s a pic of the speedo with brake light and high beam indicator lit up.
Since my car is a 1975 California car, it has a floor temp warning light and catalyst warning light.
Here’s a pic of the bulbs tested for the catalyst warning light.
Bulb 1. - Stock tungsten 74 Mini Wedge Bulb.
Bulb 2. - Red LED 74 Mini Wedge Bulb.
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/74-led-bulb-1-smd-led-miniature-wedge-retrofit-car/227/
The stock bulb is really dim.
The LED is much brighter.  Even though it does not show in the pic, it is nice and red when seen in person.
Here’s a pic of the bulbs tested for the floor temp warning light.
Bulb 2. - Amber LED 74 Mini Wedge Bulb.
Here’s a pic of the bulbs tested for the rear defogger light.
Bulb 2. - Blue LED 74 Mini Wedge Bulb.
Bulb 3. - Warm 3000k LED 74 Mini Wedge Bulb.
https://www.superbrightleds.com/moreinfo/instrument-cluster-gauge/74-led-bulb-1-led-miniature-wedge-retrofit-car/226/
The Stock Bulb is really dim.
Bulb number 2 is way too bright for a bulb that will stay on and not a warning light.
Bulb 3 is perfect.  Brighter than stock, but not overpowering.  To the naked eye its really similar to the look of the stock bulb, just brighter.  3000k is really close to the 2800K color temp. of tungsten bulbs.
Here’s a pic of the bulbs tested for the hazard light switch.
Bulb 2. - Green LED 74 Mini Wedge Bulb.
The fuel warning light is a standard BA9s tungsten bulb.
Here’s a pic.
I replaced the stock tungsten bulb with the same one used in the brake warning light inside the speedo.
It’s brighter than stock but not excessively so.
Here’s a pic of the bulbs tested for the fasten seat belts warning light.
The stock bulb is pretty dim.
The cigarette lighter socket and the HVAC controls both use 194 Wedge bulbs.
I don’t have a pic of the cigarette lighter socket but I do have one of the HVAC controls replaced with an LED.
This is the bulb used.
https://www.superbrightleds.com/moreinfo/boat-miniature-wedge-bulbs/194-led-boat-and-rv-light-bulb-6-smd-led-tower-miniature-wedge-retrofit-106-lumens/2489/4112/
The map light was also replaced with LED’s.  When I had my combo switches re-built a couple years ago I sprung for the map light LED from Dave at www.datsun-240z-upgrades.net.
Here’s a pic of the stock bulb.
Here’s a pic of the LED bulb from datsun-240z-upgrades.net.  It’s way brighter and the map light is actually very useful now.
The only interior bulbs not replaced with LED's in my car are the dome light and the glove box light.  I swapped an LED in the glove box light but it did not work.  The polarity needs to be reversed and I didn't get around to it yet.
Here's my bulb count so far for a '75 2+2.
Speedometer:
(2) BA9s bulbs for illumination
(1) BA9s for High Beam Indicator
(1) BA9s for Brake Light Indicator/Warning
Tachometer:
(2) BA9s for Turn Signal/Hazard Flashing Indicators
Temp/Oil Gauge:
(1) BA9s
Clock:
(1) BA9s
Amp/Fuel Gauge:
(1) BA9s
Catalyst Light:
(1) 74 Mini Wedge
Floor Temp:
(1) 74 Mini Wedge
Rear Defogger:
(1) 74 Mini Wedge
Fuel:
(1) BA9s
Fasten Seat Belts:
(1) 74 Mini Wedge
Hazard Switch:
(1) 74 Mini Wedge
Cigarette Lighter Socket:
(1) 194 Wedge
HVAC Controls:
(1) 194 Wedge
Glove Box:
(1) BA9s
Map Light:
(1)  Might be 194 Wedge, not sure on size, replaced with LED from datsun-240z-upgrades.net
  • 1 month later...
heres mine, i didnt like the hotspots that the replacement wedge bulbs created, so i used LED strips instead, giving me perfect and even light distribution.  the pics show a fairly blue light, but thats because the camera phone couldnt handle the white balance correctly, i chose a fairly neutral to natural color.  also forgot to put in the signal indicator shields at the time.
pretty sure i used these, if not, the brighter ones
https://www.superbrightleds.com/moreinfo/flexible-led-strip-lights/led-strip-lights-12v-led-tape-light-with-lc2-connector-114-lumens-per-ft/1464/
i use a pwm dimmer, took it out of the enclosure and stuck it in the stock location.
https://www.superbrightleds.com/moreinfo/single-color-dimmer-switches/ldk-8a-12-24-volt-dc-single-color-led-dimmer/62/365/
Edited by narth327
