  zcarnut said:
I think you can still get the rack bronze sleeves (fiche #4) the pinion bearing (#10) and the pinion bushing (#3) which should be replaced or at least inspected during a rack re-build.
I know this is a blast from the past, but I can't read the part numbers from the xenons30.com fiche for these parts. Could someone give me a hand? Rack is from a 72' 240z.
Datsun 240Z/260Z/280Z Steering Gear (Rack & Pinion Type)
Much better pictures and part number listings.
Courtesy is only showning the bearing (#10) as being available anymore.... No big surprise. I'll call Nissan Canada and see what I can dig up.
Nope sorry 48127-78500 and 48128-78500 are not available here either.
Edited by zKars
Guys,
FWIW I just was able to order the following from Courtesy:
Key Part Number Description Quantity Price
4 48127-78500 BUSH-STEERING RACK (1) $7.91
10 48018-E8700 BEARING-PINION STEER (1) $16.73
13 48125-78500 SEAL-OIL PINION U (1) $2.59
22 48203-N3000 BOOT-STEERING GEAR (2) $104.98
23 48055-E8700 CLAMP-DUST COVER UPP (4) $9.16
24 48054-78500 CLAMP-BOOT STEERING (2) $2.54
Awww snap!
"Dear Mr.Blair,
Thank you for your order. This is to let you know that Nissan has informed
us that part #48125-78500 [sEAL-OIL] is now no longer available. However,
I did locate several dealerships in the US that list one of these ??s in
their inventory. We will contact them and, if they actually have it
(sometimes these listings are inaccurate or the part is being held for
another customer), we will procure it from them and then ship it to you.
If they do not have it we will issue a refund.
us that part #48055-E8700 [CLAMP] 48018-E8700 [bRNG-PINIO] (OEM part
#48055-E8700, 48018-E8700) is now no longer available."
Back on the hunt again... I wonder if I can source the bearing straight from Koyo or cross reference it.
Ahhh.... Yo Ho Yo Ho a Z's Life for me.
Jay
Dang it. There is a good chance you can find a bearing from a generic source. Take it with you to a big drivetrain or bearing shop. Measure it and check on line to see if find one. Read the fine print on the bearing itself for an SKF or similar part number.
Guys,
A couple of things I have come up with:
1) WAS able to find the bushings for the rack (48127-78500 - Courtesy) & (48128-78500 - Smith Family Nissan (580) 225-3344)
2) Pinion bearing is a standard part in the industry 6003RS (17x35x10) that you can find anywhere for around $10 - helped when I got out the readers and could see it was an "S" and not a "5"!!!
3) The bellows I am using, per the rebuilding rack thread on here, are EMPI 88-1509K ~$15/side from Amazon
4) Still hunting the oil seal (Courtesy is looking across the dealerspace for me)
Thanks Again for the assists!
Jay
Jay, I found a Timken crossover part number for the oil seal you might be able to look for, Nissan 48125-78500 SEAL-OIL crosses to Timken 221735. See this link for the info on page 149:
http://www.timken.com/en-us/products/Documents/Timken_Seal_Interchange_and_Cross_Reference_Guide.pdf
Timken is the parent for National Industrial Seals, and are best sourced from any industrial bearing house, like Kaman Industrial Technologies.
HTH Mike
While looking for seal specs I found this source:
National 221735 - Oil Seal | O'Reilly Auto Parts
Edited by CanTechZ
Mike,
If that is the case, and after looking at the Kalman site, I think that the steering rack bushings, pinion bushing, pinon bearing and the oil seal all might be able to be sourced after market. I will need to break out my digital mic and do some careful measuring.
Thanks!
Jay
