Sean Dezart Posted November 30, 2002 Share #1 Posted November 30, 2002 Can anyone help me findan outlet perhaps via Interent and the old world side of the Atlantic for some Hellas. None of my search engines can come up with an address ? I have followed your lighting discussions and will uprate the wires and fit more powerful bulbs but first, the lights.Thanks Link to comment Share on other sites More sharing options...
Ivan Posted December 1, 2002 Share #2 Posted December 1, 2002 There might be something on the international section here:http://www.hella.co.nz/ Link to comment Share on other sites More sharing options...
Doehring Posted December 2, 2002 Share #3 Posted December 2, 2002 Sean, try www.hella.de. I have Hellas in my Z. The exchange from the american closed bulps was quite difficult while using the original front light housing and the chrome ring. I heared that the VW Golf 1 front lights also suit. Try to get them from a scrapyard. By the way, Motorsports has the Hellas in their catalog. You can ask them via e-mail for technical advise/help.Rolf Link to comment Share on other sites More sharing options...
2ManyZs Posted December 3, 2002 Share #4 Posted December 3, 2002 Sean, check out our newest advertiser. Too Intense Restorations also has an H-4 conversion kit for 56.95 each side..Not sure how much shipping would be but it might be worth a look. Link to comment Share on other sites More sharing options...
Sean Dezart Posted December 3, 2002 Author Share #5 Posted December 3, 2002 Thanks I'll check them out (ideal is to find them here in Europe but...) Iwant to share this with youDear Mr. Dezart,Your E-Mail dtd. 02.12.02 was transferred to our department and afterhaving checked your enquiry with our technicians who are responsible forlighting products we unfortunately have to inform you that we do not haveany longer 7" headlamps in our range. As we do not stock products forOldtimers we consequently can not offer corresponding headlamps for yourDatsun 240 Z. The only possibility we see is that you contact your localdealer or accessory shops and ask for auxiliary lamps which are availableas fog lamps or as driving lamps and which can be mounted onto the bumperrespectively underneath it in addition to your old healdlamps. For examplewe can recommend here our Comet FF 200 (round) or Comet FF 300 (oval) whichhave achieved an excellent result in various tests which were alsopublished in the automotive press.Best regardsHeike Räbiger(Export Sales North,/West- and South Europe VG 2-1)They still list Datsun 100As, Silvias and 280ZXs amongst many others !Aren't there enough Zeds out there to warrant continuing production ? Link to comment Share on other sites More sharing options...
Rogersz Posted December 4, 2002 Share #6 Posted December 4, 2002 Sean they are readily available here in Australia # 1056 178mm without park light globe holder# 1058 178mm with park light globe holder# 5604/100 conv kit/paironline catalogue is www.hella.com.authere are plenty of english cars that used 7 inch round lamps surely they would be avail in the u.k.also Narva do H4 halogen inserts, most of the 240Z'S at a recentAdelaide classic car rally had the narva's installed. IF you get desperate i can get either brand for you. regards Roger Link to comment Share on other sites More sharing options...
Sean Dezart Posted December 4, 2002 Author Share #7 Posted December 4, 2002 Thanks RogerI'll check out the Hella aus site and thanks for the offer to supply.UK lights won't do 'cos they drive on the wrong side of the road and the beam angle is all wrong ! Link to comment Share on other sites More sharing options...
Mike Posted December 4, 2002 Share #8 Posted December 4, 2002 There's another thread about Hella's here:http://www.classiczcars.com/forums/showthread.php?s=&goto=newpost&threadid=4753 Link to comment Share on other sites More sharing options...
Sean Dezart Posted December 4, 2002 Author Share #9 Posted December 4, 2002 I'm gettin' really pissed - I'm getting nowhere and it aint your fault guys.The reason for choosing Hellas is to improve over the standard lighting but clearly there are now better lights out there although not of the sealed beam type or look.Are these 'diamond' lights going to look ok on a 1972 car , I don't want to associate myself with the 'tuning' brigade of add-on wannabes ?And so, does one choose Neon or 'krypton?' gas filled bulbs and at what strength - I hear someone say 90/110 but why ?Help, my head is hurting... Link to comment Share on other sites More sharing options...
Z-point Posted December 4, 2002 Share #10 Posted December 4, 2002 sean,shall I try to buy them in Holland for you??I've got Hella's on my Z as well. Link to comment Share on other sites More sharing options...
Shiin Posted December 6, 2002 Share #11 Posted December 6, 2002 There are a lot of companies that make the H4 conversion out there, but the problem is if you want to meet legal requirments.Companies such as autopal make headlight that meet european requirement as well as DOT. I have the autopal H4 conversion in and they go in fine using the stock components to the headlight assembly.I argee with using another bulb such as the Narva bulb. I have some laser white lights that I picked up at a local turners shop that are 60/55W and are slightly brighter then the 100/90W sealed beams.If you do choice a bulb that is higher then the 60/55W you will have to upgrade the wiring to the light to prevent electrical failure. This would require 2 automotive relays and a waterproof fuse w/case as well as heavier guage wire.keep in mind that the stock lights to the Zed is 7" or 178mm. Link to comment Share on other sites More sharing options...
