240 K VIN location help!!
circuitlife86
Hey guys, long time lurker on here and I obviously rarely post but I'm having an issue with a 240 K that I'm in desperate need of finding a secondary VIN location on. I searched my arse off but I haven't been able to find any information regarding the matter. It turns out that one of the genius previous owners tried passing the car off as a K"P"GC110 by modifying the "H" to look like a "P" on the stamping on the firewall and there has never been a secondary VIN plate attached. Obviously this is going to cause a bit of a red flag when we register the car and have the VIN inspected. My question is does anyone know if there may be another VIN stamped into the frame rails or somewhere else? I know the Z's, and Hakosukas have them there but I haven't been able to spot any on the C110 chassis. If I can find an unmolested VIN I can get it properly registered.
If anyone has any info it would be GREATLY appreciated, thanks in advance.
All C110-series Skyline body serial numbers are engraved on what the factory described as the 'cowl top' in the engine compartment, but might be better described as the firewall sheetmetal. The 'Car Identification Plate' - otherwise known as a 'VIN tag' or 'Data Plate' is alongside. These are the only two places on the car where the body serial number is recorded.
We have discussed that particular car on this forum several times in the past, so I'm presuming you have seen those threads? Here are links to some of them:
http://www.classiczcars.com/forums/showthread.php?t=12221
http://www.classiczcars.com/forums/showthread.php?t=12259
http://www.classiczcars.com/forums/showthread.php?t=24937
http://www.classiczcars.com/forums/showthread.php?t=29117
Alan T.
Thanks a million Alan. And yes I have seen most of those threads, you guys really get in to some heated VIN, or shall I say "chassis serial number" conversations ;)
I'm trying to get this resolved once and for all and get the car officially titled as an "H" car so no one else has to go through all of this again because some tool decided he would get artistic with a chisel and try to pull a fast one. I had really hoped it would be stamped elsewhere on the car correctly like some other Nissans and Datsuns of the era but unfortunately I'm going to have to find another solution.
Thanks again for the reply Alan.
