Posted December 20, 201014 yr comment_339313 Can anyone supply the stock 1970 cam specs? Lift, duration, etc.Mike Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/ Share on other sites More sharing options...
December 20, 201014 yr comment_339325 I believe that the stock 240Z had an advertised duration of 270 degrees and a lift of .410 inches. Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339325 Share on other sites More sharing options...
December 20, 201014 yr comment_339346 I believe that the stock 240Z had an advertised duration of 270 degrees and a lift of .410 inches.Oh no Guy, the stock cam is much smaller, IIRC 270 is a stage II.Mike, have a look here, there should be a letter stamped in your cam as you see on the page, witch will refer to the "cam mark" on the spec. sheet.Chris Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339346 Share on other sites More sharing options...
December 20, 201014 yr comment_339358 Chris.....Isky lists it's Stage I cams at 270 degrees advertised and 222 degrees at .050 inches (same as stock).See link below.http://www.iskycams.com/onlinecatalog.html Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339358 Share on other sites More sharing options...
December 20, 201014 yr comment_339375 So Guy, what youi are saying is that the duration listed in the Nissan L serie spec sheet, is at .050 inches?Chris Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339375 Share on other sites More sharing options...
December 20, 201014 yr comment_339381 Isky didn't know what valve lift the factory uses........Isky uses .050 valve lift. Advertised duration at Isky is at .020 valve lift. They show an advertised duration of 270 degrees (at .020 inch valve lift) and 222 degrees (at .050 inch) for the stock 240z camshaft. Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339381 Share on other sites More sharing options...
December 20, 201014 yr comment_339382 Sorry if i get a little confused about all this, but what you are saying is that Nissan A cam (248) is the same as Isky stage I, i run a Nissan C cam (256) what would that be at .050 inch lift?Chris Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339382 Share on other sites More sharing options...
December 20, 201014 yr comment_339384 http://www.iskycams.com/onlinecatalog.htmlThe Isky Stage I is a stock 240Z camshaft reground to a higher lift (.475 vs .413), but with the same duration as stock. Click on the above link, on the left, click on Datsun,then on L24 page 176. For the Stage I regrind they list duration at .050 lift at 222 degrees and indicate that that is the same duration as stock.. Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339384 Share on other sites More sharing options...
December 20, 201014 yr comment_339386 I did look at the link, but didn't see the comparison (10 inch netbook), so the stage II is the same as the C cam with a little higher lift, that is very interesting to know.Guy, did you take a look at the link i provided above? Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339386 Share on other sites More sharing options...
December 20, 201014 yr comment_339388 Chris.....Yes, duration can be confusing because manufacturers may select any lift to advertise duration. It would be interesting to see what Nissan used to come up with 248 degrees duration. If .020 lift is 270 and .050 is 222, it must be somewhere in between. Guy Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339388 Share on other sites More sharing options...
December 20, 201014 yr comment_339390 270 + 222 / 2 = 246 at .060 witch is just about 1.5 millimeter, it might not be that simple, but it make sense.Chris Link to comment https://www.classiczcars.com/forums/topic/37992-cam-specs/#findComment-339390 Share on other sites More sharing options...
