Posted December 20, 201014 yr comment_339350 I have a 76 280 (7/76)and just aquired a set of used tail lights for it. My car has the small harness connectors and the new lights have the large connectors. What years were different and what is my best option?Thanks in advance. Link to comment https://www.classiczcars.com/forums/topic/37996-280z-taillight-harness-connectors/ Share on other sites More sharing options...
December 20, 201014 yr comment_339389 You can buy replacement connectors from Vintage Connections. I have purchased a lot from Del. He is a good man to buy from. Many others here will agree. If you carefully work the old terminal out of the connector, many times you can re-use it in the new connector. Link to comment https://www.classiczcars.com/forums/topic/37996-280z-taillight-harness-connectors/#findComment-339389 Share on other sites More sharing options...
December 21, 201014 yr Author comment_339403 Thanx, Steve Link to comment https://www.classiczcars.com/forums/topic/37996-280z-taillight-harness-connectors/#findComment-339403 Share on other sites More sharing options...
