Posted December 23, 201014 yr comment_339665 hey gang------i just replaced my lamp/wiper switch on my series-1 240z. that is to say, i bolted it back on the steering post and reconnected the pig-tail. i forgot to "mark/tag" the other wires when i removed the broken switch.Q: what wire/color goes where?i thank you in advance for any thoughts or suggestions.BTW----seasons greetings to all! Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/ Share on other sites More sharing options...
December 23, 201014 yr comment_339670 If it's the proper switch, you should have a 6 wire connector and maybe a couple of other wires. The connector only goes on one way. The other wires should be the same colors as the wires they go to.Is there something I'm missing here? If so, post pictures. Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339670 Share on other sites More sharing options...
December 24, 201014 yr Author comment_339678 If it's the proper switch, you should have a 6 wire connector and maybe a couple of other wires. The connector only goes on one way. The other wires should be the same colors as the wires they go to.Is there something I'm missing here? If so, post pictures.yeah, i guess that's the problem. while the wiring/colors from the new switch appears to be factory/stock - some of the "receiving" wires/colors are not. my only "color" match(s) are the 6-wire connector, a solid/black wire and a solid/red wire(from turn signal switch). with that said, both wipers and r-tail lights work; no head lamps. Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339678 Share on other sites More sharing options...
December 24, 201014 yr comment_339694 Are all of the wires on the new switch connected to something now? Are there the same number of wires on your old switch? Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339694 Share on other sites More sharing options...
December 24, 201014 yr comment_339702 Large black to Large Black6-pin to 6-pinRed on switch to redwhite with red stripe to white/redBlue/white to black/yellow (sometimes)And here's the fun part.......There should be a smaller Black wire that needs to connect to the Wiper switch.That wire is the headlight ground wire that the turn signal switch controls Hi and low beam with...Most people forget to connect the 2 switches together.Click this link and the second picture on the first post should show you the wire I'm talking about. The turn signal wire can be either black or red....http://www.classiczcars.com/forums/showthread.php?t=30640Dave Edited December 24, 201014 yr by Zs-ondabrain Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339702 Share on other sites More sharing options...
December 24, 201014 yr Author comment_339748 Large black to Large Black6-pin to 6-pinRed on switch to redwhite with red stripe to white/redBlue/white to black/yellow (sometimes)And here's the fun part.......There should be a smaller Black wire that needs to connect to the Wiper switch.That wire is the headlight ground wire that the turn signal switch controls Hi and low beam with...Most people forget to connect the 2 switches together.Click this link and the second picture on the first post should show you the wire I'm talking about. The turn signal wire can be either black or red....http://www.classiczcars.com/forums/showthread.php?t=30640Daveit works!you nailed it my friend.i can't wait to drive my z around town tonight to enjoy the christmas lights.in my book you guys are the greatest friends a z owner can have - much thanks!-------Jerry Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339748 Share on other sites More sharing options...
December 24, 201014 yr comment_339751 So was it the black cross-over wire to the Turn signal?Glad to help, Happy Holidays,Dave Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339751 Share on other sites More sharing options...
December 24, 201014 yr comment_339756 I'm sure it was. I didn't even think of it the first time because I just connected it when I changed out my switch. I didn't even think twice about it. I believe Del at Vintage Connections even sells replacements for them. Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339756 Share on other sites More sharing options...
December 25, 201014 yr comment_339762 Ahh, Steve, .... I think Dave was asking Jerry if that's what it took to fix it. I'm sure Dave is happy you fixed yours too.E Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339762 Share on other sites More sharing options...
December 25, 201014 yr comment_339763 Ahh, Steve, .... I think Dave was asking Jerry if that's what it took to fix it. I'm sure Dave is happy you fixed yours too.EI knew Dave was addressing it to Jerry, but I also know in my head that it was the missing link, considering I had replaced my own switch a few months ago. I studied that connector some since it looked unique to me, but it didn't come to mind when Jerry originally posted his problem. Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339763 Share on other sites More sharing options...
December 25, 201014 yr comment_339764 Either Way, I'm glad to help and happy that both of your guy's switches are working properly.Dave Link to comment https://www.classiczcars.com/forums/topic/38030-head-lampwiper-switch/#findComment-339764 Share on other sites More sharing options...
