I have these bwa wheels and going to post in classifieds.. my question is how do i measure width of wheel? i measured from outside to outside and came up with 7in. is this correct way?
https://www.classiczcars.com/forums/topic/38047-wheel-measurement/
thanks..so they are 6 inch?
Yes, they are 6" width. You measure the width from inner bead to inner bead with the tires off the rim https://www.rsracing.com/tech-wheel.html. Those also look like they are stamped 13" (diameter), not 14".
-Mike
Mike, they are 14". It may not be clear at the rim but look at the tire.
Yep, you are right, they are 14". I didn't think to look at the tire. Now that I look at the rim on my desktop computer I can make out the 14 now. Sorry about that.
-Mike
