Thinking about an rb30 build for my 76 z. Does anyone know where to source one from and what would be required for the swap(what type of trans, ecu, wiring harness etc.)
I have driven an R31 Skyline with the RB30 engine in it. Smooth, torquey and quite fuel efficient is how I would describe it.
That's how I would describe a well sorted L28 as well. I really don't see much of an advantage by running an RB30.....once the bonnet was closed nobody could really notice much of a difference.
But if you really must gotta have one.......
Good luck mate.
An RB30 is good.
With an RB25DE[T] head on it is even better;)
The RB30 was a Japanese engine sourced for the 1986 Holden Commodore in the Oz market.
A great engine, don't get me wrong, BUT, it was a single cam, 12 valve engine with a dodgy optical distributor.
Take its' head off and replace it with a twin cammer 24 valve head and BELOW AND HOLD, a very nice combination:love:
The RB series is renown for robustness and the typical Nissan compatibility across the range allows you to build a hybrid very easily.
e.g. the RB30 block has a cast in boss exactly where you need to drill for the timing belt idler pulley mount required for the twin cam conversion:classic:
As a bonus, when you get the head off an RB30, the pistons have a 4 valve cutout!
So obviously the engine was originally designed for a 4 valve head!
Edited by Nissanman
Nissanman thanks for the info, gives me a new bases for research. The l28et I had was was pushing 368hp at 312trq. Very strong and quick z. I would never talk bad about that motor I liked it! But with this z build I wanted something different, I'm sure the power from an a rb30 would offer me a new kind of power that I'm interested in.
My previous z was a complementary built of what a l28et s30 should be built. I want this z to take on all new characteristics and push my creativity and Pride to a new level. Btw the Z's I build are purpose built circuit racers. So while on the vague topic of Rb30 if anyone has seen a full racing set up like this let me know where to look
I've got a condensed FSM for the Holden version of the RB30.
If you need me to scan you any parts let me know.
The Holden version is basically identical to the Nissan engine fitted to the R31 Skyline barring the omission of the text NISSAN on the parts:rolleyes:
Badge engineering at its' best;)
Edit:
Here is a link to two files I have uploaded to Rapidshare.
R33 Repair Manual and a bonus file.
These were on a CD that I got on eBay.
Unfortunately they are NOT search able but you are welcome to download them if you find them useful.
Use the "export links" text to download.
R33
Edited by Nissanman
Added link to R33 Repair Manual and bonus file.
