Posted December 30, 201014 yr comment_340174 I did a search and not much popped up. I was browsing on a few forums and noticed some rwd cars with a larger width/diameter wheel for the rear. Example: 15 front and 16 rears. From what I've learned it is purely cosmetic. Has anyone tried this before? Link to comment https://www.classiczcars.com/forums/topic/38070-anyone-have-larger-diameter-for-rear-wheels/ Share on other sites More sharing options...
December 30, 201014 yr comment_340182 Changes gear ratios unless you match overall tire diameter, adds rake to stance, and makes a tire change difficult should you ever get a flat.Been done before, on S30 cars for racing purposes but then it was 14 and 15 inch wheels.See Burton Brown's land speed record 240Z. Link to comment https://www.classiczcars.com/forums/topic/38070-anyone-have-larger-diameter-for-rear-wheels/#findComment-340182 Share on other sites More sharing options...
December 30, 201014 yr comment_340194 Just another example of staggered wheels. Link to comment https://www.classiczcars.com/forums/topic/38070-anyone-have-larger-diameter-for-rear-wheels/#findComment-340194 Share on other sites More sharing options...
December 30, 201014 yr comment_340202 I plan on putting 16's all the way around on my car once I wear out the tires that are on now. The outer circumfrence will remain the same. I want to eliminate the sidewall flex. With the 60's that are on there, if I stand next to the car and repeatedly push it sideways, there is a significant amount of movement. This will go away with a 50 or 55 profile of the same width. Putting larger wheels on the rear only (while keeping overall circumfrence the same) might help to induce oversteer a bit, but that's pure speculation. Edited December 30, 201014 yr by tlorber Link to comment https://www.classiczcars.com/forums/topic/38070-anyone-have-larger-diameter-for-rear-wheels/#findComment-340202 Share on other sites More sharing options...
