March 30, 201312 yr comment_419167 Exactly. I learned the hard way what happens when you put them in the wrong way. When you tap them in the wrong way, they can grab the seal and slice the rubber. Link to comment https://www.classiczcars.com/forums/topic/38073-fk-i-think-my-brand-new-rear-main-seal-is-leaking/?&page=7#findComment-419167 Share on other sites More sharing options...
March 30, 201312 yr comment_419182 Jeff,thanks for all the info and the clarification on these side seals. I'm hoping this will cure my issue and this thread will surely help out others.Jeff, you should consider coming down for the Midwest Z show in Nashville Indiana! Link to comment https://www.classiczcars.com/forums/topic/38073-fk-i-think-my-brand-new-rear-main-seal-is-leaking/?&page=7#findComment-419182 Share on other sites More sharing options...
March 30, 201312 yr comment_419184 When is it Steve? Link to comment https://www.classiczcars.com/forums/topic/38073-fk-i-think-my-brand-new-rear-main-seal-is-leaking/?&page=7#findComment-419184 Share on other sites More sharing options...
April 7, 201312 yr comment_419761 Sorry jeff, missed your reply-week-end of the june 16th by the way, it still leaks Link to comment https://www.classiczcars.com/forums/topic/38073-fk-i-think-my-brand-new-rear-main-seal-is-leaking/?&page=7#findComment-419761 Share on other sites More sharing options...
April 7, 201312 yr comment_419767 Ugggghhhh! I'm sorry to hear you still have a leak Steve. Depending on how the prep on my 260Z race car goes, I might be able to make the 16th. I'm building a new motor and I have a bunch of other mods to do as well. The plan is to have it ready for a track day at Grattan at the end of May. If we get it ready in time and that testing goes well, June will be pretty quiet, but if it needs additional work, I'll be thrashing to get it ready for our 12 hour July race at Nelson Ledges.I hope to get my street Z out of the garage pretty soon too. Last year, it stayed in the corner of the garage with the cover on it all summer. Link to comment https://www.classiczcars.com/forums/topic/38073-fk-i-think-my-brand-new-rear-main-seal-is-leaking/?&page=7#findComment-419767 Share on other sites More sharing options...
April 7, 201312 yr comment_419777 I just tapped the seals in with a hammer. I'm not good in English, but I never had to use a hammer to get seals in...It's important to use alot of oil on the seal when installing ( or else you will damage the rubber, and it will be damaged on first start of the engine ), I usually just drip it into the oil. Then push the seal in place with a little clockwise rotation with your fingers. Some seals might need a little help, but very gently with the right driving tool. I also seen alot of seals pushed to deep.Harder seals aren't always better, usually I prefer the softer versions. Link to comment https://www.classiczcars.com/forums/topic/38073-fk-i-think-my-brand-new-rear-main-seal-is-leaking/?&page=7#findComment-419777 Share on other sites More sharing options...
April 7, 201312 yr comment_419785 The hammering is referring to the side seal pins, not the crank seal. Link to comment https://www.classiczcars.com/forums/topic/38073-fk-i-think-my-brand-new-rear-main-seal-is-leaking/?&page=7#findComment-419785 Share on other sites More sharing options...
