June 12, 201113 yr Author comment_358479 Some more pics. Went up today and helped put the hood, fenders and doors on. A few more small parts to clean up, and he's going to block the fenders out then paint will follow. Link to comment https://www.classiczcars.com/forums/topic/38095-my-body-repair-progress/?&page=5#findComment-358479 Share on other sites More sharing options...
June 16, 201113 yr comment_358965 Cozye, I'm really enjoying looking through this post. You're doing great work and I admire anyone who can do that level on there own! I have a few questions: When you're cutting out pieces like this repair below, what tool are you using to cut with? A metal cut-off wheel? What are you using to bend the sheet metal? Lastly, how many amps is your welder? I'm contemplating buying one but not sure what MIG setup is best. Any advice would be appreciated. Thanks! Link to comment https://www.classiczcars.com/forums/topic/38095-my-body-repair-progress/?&page=5#findComment-358965 Share on other sites More sharing options...
June 17, 201113 yr Author comment_358978 For the cuts I was using an air powered cut off tool with the normal disc.As far as the sheet metal fabrication, I used several methods. On the hatch jamb, I used a metal brake and hammered out the corners with a body hammer on a vice. For the rocker patches behind the fenders, I used a combination of a metal brake, pliers, and welding together pieces to get the same i wanted. For the dog legs, I just cut a section out of a tabco patch panel, and had to slot it a little and bend it a little more since it didn't fit perfect. Basically I just figured out how to work with what I had to make the shapes I wanted, got it close, dollied it out a little when I needed to and a small bit of plastic. The rear quarter panel patches I just bent by hand and a brake.I bought an eastwood mig welder. The had great reviews, were much cheaper than the typical lincoln/hobart/miller home welders, and they have infinetely adjustable/variable voltage settings instead of just 5-8 clicks like a lot of them. High end welders have the same type of variable voltage adjustment which is really nice to fine tune your heat settings when welding thin sheet metal. I bought the mig 135 110v version which is fine for all my needs and strong enough to weld up to 1/4" or so thick.http://www.eastwood.com/welders/eastwood-welders-1.html Link to comment https://www.classiczcars.com/forums/topic/38095-my-body-repair-progress/?&page=5#findComment-358978 Share on other sites More sharing options...
June 17, 201113 yr comment_358980 Great information. I appreciate it! Your work looks great by the way! Link to comment https://www.classiczcars.com/forums/topic/38095-my-body-repair-progress/?&page=5#findComment-358980 Share on other sites More sharing options...
June 24, 201113 yr Author comment_359709 Color is on the car! Still needs to be color sanded and buffed, but it's looking good. Link to comment https://www.classiczcars.com/forums/topic/38095-my-body-repair-progress/?&page=5#findComment-359709 Share on other sites More sharing options...
June 24, 201113 yr comment_359722 Nice!! Link to comment https://www.classiczcars.com/forums/topic/38095-my-body-repair-progress/?&page=5#findComment-359722 Share on other sites More sharing options...
June 25, 201113 yr comment_359756 Looks great.The pictures have a familiar look to them:love:Casey Link to comment https://www.classiczcars.com/forums/topic/38095-my-body-repair-progress/?&page=5#findComment-359756 Share on other sites More sharing options...
June 26, 201113 yr comment_359800 Thats nice and it is a credit to you . Brian Link to comment https://www.classiczcars.com/forums/topic/38095-my-body-repair-progress/?&page=5#findComment-359800 Share on other sites More sharing options...
