April 30, 201113 yr comment_354497 Replaced Oil Pan Gasket, Front Seal, Upgraded to 280ZX turbo oil pump, and replaced all exterior bulbs with LED's. This was last weekend...today we drive. Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-354497 Share on other sites More sharing options...
May 2, 201113 yr comment_354642 I picked up boxes of spare parts from the previous owner and tried to organize them. Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-354642 Share on other sites More sharing options...
May 2, 201113 yr comment_354651 That's almost a new car Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-354651 Share on other sites More sharing options...
May 28, 201113 yr Author comment_357118 Minor maintenance time. The car slowly developed a bit of rear clunk again. After the transmission rebuild and R-T mount install, it was pretty much clunk-free, so I decided to check it out. Traced it to the outer u-joint in the left half-shaft. Replaced it with one of my spare half-shafts, and it is once again very tight.Got to re-seal the diff one of these days, though... Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357118 Share on other sites More sharing options...
May 28, 201113 yr comment_357128 I replaced the boot on the firewall for the throttle today. I also detached the speedometer cable from the speedometer to replace it. I noticed a wire going through the grommet for the speedometer cable, so I traced it. One end went to the positive side of the coil. I followed it under the drivers seat and up the back and under the carpet on the rear deck. It continued over to the passenger side taillight where it was poorly jury-rigged to the fuel pump. The wire was nice and brittle for the full length and poorly spliced in a couple of places.After I replace the speedometer cable, I'm going to look at the fuel pump relays to make sure they work. Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357128 Share on other sites More sharing options...
May 28, 201113 yr comment_357131 Just about finished welding in a new passenger floor pan. Now time for a little grinding. Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357131 Share on other sites More sharing options...
May 28, 201113 yr comment_357134 Wished it wasn't over 2,000 miles away and that It hadn't been 4 1/2 years since I've seen it. jlpI want to drive it again! I haven't driven it for 35 years! Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357134 Share on other sites More sharing options...
May 29, 201113 yr comment_357141 JLPurcell said: Wished it wasn't over 2,000 miles away and that It hadn't been 4 1/2 years since I've seen it. jlpI want to drive it again! I haven't driven it for 35 years!I've probably seen your car more than you have these last two years. It looks great :-) . If I can remember, I will take pictures of it next time I stop by Les's place.Rich Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357141 Share on other sites More sharing options...
May 29, 201113 yr comment_357149 Added some nice eye candy to the Fairlady's engine bay today with this new Kameari heat shield I purchased from ZCCJDM. I replaced an older ugly-looking piece. :classic: I thought it turned out very nice Edited May 29, 201113 yr by spitz17 Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357149 Share on other sites More sharing options...
May 29, 201113 yr comment_357169 motorman7 said: i've probably seen your car more than you have these last two years. It looks great :-) . If i can remember, i will take pictures of it next time i stop by les's place.Richthat would be great, and highly appreciated. Jlp Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357169 Share on other sites More sharing options...
May 29, 201113 yr comment_357189 Still finding PO things to fix (8 months after purchase). The heater control cables went to the wrong items. 73 Z w/ after market a/c. The a/c covers up the fresh air door, so I can't loosen that cable. Got the other 3 loose and had enough slack to pull the control unit out far enough to un-do the door control from the other end. Now when I ask for fresh air, I get fresh air. When I ask for defrost, I get defrost. Life is more good.Now for some beautiful day holiday driving. Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357189 Share on other sites More sharing options...
May 29, 201113 yr comment_357224 Well after 6 yrs of collecting parts and working on my 73, I started it up for the first time today ( I have never heard this car run ). I've done a 2..8 N42 with flat tops, an E-88 head with a C-grind, Mallory dual point distributor with Pertronix II and matching coil, MSA header, and 3 Dell's on a Cannon manifold. I also did the fresh stuff like HV oil pump, water pump, timing kit, ect. After priming the fuel, it fired on the first hit. It stumbles a bit off idle, must be lean but it sure sounds great. Now on to the master cyl to finish off the brakes so I can run it around the block. Maybe I'll do a YouTube later today. Edited May 29, 201113 yr by 240ZGL Link to comment https://www.classiczcars.com/forums/topic/38099-2011-what-did-you-do-towith-your-s30-today/?&page=10#findComment-357224 Share on other sites More sharing options...
