Posted December 2, 200222 yr comment_20127 I have a 70 240 which has glass in the rear hatch without demister strips, the other 70 240 that I had was the same and so is the car of a friend of mine.At what point did they start to fit demister strips or is this just an Australian thing?The hatch has it's original glass with nissan info stamped into the bottom corner.The rear of the centre consul also has the cut outs for the demister switch but no button.I don't need to replace the glass or anything, just looking to increase my knowledge of my particular car.RegardsLee Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/ Share on other sites More sharing options...
December 2, 200222 yr comment_20132 The rear demister was a factory option. All cars have the wiring & all consoles have the boss for the switch. Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-20132 Share on other sites More sharing options...
December 3, 200222 yr comment_20170 My Australian 1973 240Z has no rear de-mister and has no hazard switch either. Both holes are in the center console (fuse box cover) but both of the them and the choke light position have factory fitted covers over them.I'd like to hook up the Hazard lights, does anyone know what wires the switch attaches to and where the flasher unit goes. I have the haynes manual but the wiring in all 3 240Z schematics is different to mine.OzLime240Z Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-20170 Share on other sites More sharing options...
December 3, 200222 yr comment_20184 I have straight glass in the hatch 12/71 and 06/73. It comes down to that option thing. It appears that a lot of cars in Australia had very few extras. like heater demister hazards and such. I have seen two distinctly diffrent styles of demisted glass in HS30 hatches one with vertical lines and one with horizontal. Sorry I can not explain why.CheersSteve :classic: Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-20184 Share on other sites More sharing options...
December 3, 200222 yr comment_20202 I've not even seen a Z here in the US without this feature.From what I've seen here and talked to Z owners about is that the verticle units were installed in the very early ('70) 240Z's. Then from that point on the horizontal units were the norm.I believe the hazard lights and switch were a DOT (Depatrment of Transportation) requirement here in the states, but I cound be mistaken on this one. Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-20202 Share on other sites More sharing options...
December 4, 200222 yr comment_20270 Just adding a comment. The vertical defogger glass is hard to find and worth quite a bit too. I remember having a conversation with Lindsey Drife(forgive for incorrect spelling if it is). At the Zshop here in Melbourne and he was saying he has 1 and no it's not for sale I'll include an image in this post so u can see the vertical lines. PS: It's TOD Kaneko's 240z I love this Z. (Forgive spelling again if wrong). Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-20270 Share on other sites More sharing options...
December 4, 200222 yr comment_20274 Originally posted by Gav240z PS: It's TOD Kaneko's 240z I love this Z. (Forgive spelling again if wrong). Hot damn... yea, that's a nice ride. Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-20274 Share on other sites More sharing options...
December 4, 200222 yr comment_20282 Just another note!My Z (manufactured 10/71) has the vertical wiring on the original hatch. Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-20282 Share on other sites More sharing options...
December 5, 200222 yr comment_20329 My '72 has the vertical wiring as well. Too bad it doesn't work very good at clearing the window. I think they changed to the horizontal pattern when they ran out of the verticals as most of the 72's I have seen are the horizontal. You guys should also know that the vertical defrosters make your Z go faster too... Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-20329 Share on other sites More sharing options...
May 2, 200321 yr comment_35897 Originally posted by GunnerRob I've not even seen a Z here in the US without this feature.From what I've seen here and talked to Z owners about is that the verticle units were installed in the very early ('70) 240Z's. Then from that point on the horizontal units were the norm. My 11/69 production car has no rear defogger in the glass, and the console position for the switch is there, but was never cut out. Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-35897 Share on other sites More sharing options...
May 2, 200321 yr comment_35919 Yes, I agree with Dave Sommers regarding the transition from verticle to horizontal defrosters. The horizontal defroster was part of the changes with '72 model years cars in the US and probably officially started when the factory ran out of the old verticle ones. Because the verticle type was used through the rest of the years of first generation Z's they are much easier to find. Therefore, it is not uncommon to see an early Z with the horizontal type defroster glass installed.Have fun! Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-35919 Share on other sites More sharing options...
May 2, 200321 yr comment_35942 My (Australian) Z has no demister strips either. I believe they changed the design of the demister strips from verticle to horizontal mainly because horizontal demister strips will be more effective at demisting than the verticle strips, because of the air flow direction. Makes sense doesn't it? Oh and from a design perspective, verticle lines make things look tall, horizontal lines make things look wide... I'm not sure if they thought about it THAT much though Link to comment https://www.classiczcars.com/forums/topic/3814-series-1-rear-hatch-glass/#findComment-35942 Share on other sites More sharing options...
