Hi guys, I recently removed my su's and air filter housing and after taking apart I noticed a hose on the air filter housing that didn't connect anywhere. I am wondering if it is supposed to be connected or not and where it would be connected if it is supposed to. Any and all help would be greatly appreciated. \
Thanks
https://www.classiczcars.com/forums/topic/38319-air-filter-housing-hose/
If I'm not mistaken, the hose in the picture would connect to the smog pump, if it is still on the engine...if the smog pump has been removed, simply remove that hose & cap off the nipple on the back of the air filter housing. Check your local auto parts stores, you should be able to find a cap that will fit.
Definitely the hose to the smog pump. It's cut shorter that it was originally, so I'm betting the pump is long gone. It would have been mounted on the left side of the block, under the distributor.
Where in Oregon do you live, Mitch? Have I seen your car around?
I'm from clackamas area. Car has mainly been in garage for last year while I work on it and go to school but should be up and running by spring time. Thanks for the help by the way.
