Tires touching Springs
luke002
By my thumbnail calculations the maximum safe offset for a 205 on the front of an S30 is about 20mm.
What is missing here is the type of wheels that are giving luke002 trouble.
WHOOOOOA there Walter. The offset should be zero for the tire he's using.
Edited by bpilati
definitely get new studs if you are putting anything bigger than a 5mm spacer, especially considering how short the original studs are as it.
im running same tire, 205/60/15 with no spring rubbing. but i have 0 offset on my 15x8 rim. you have an offset issue.
