I have a 1971.5 240Z, the car came with a series one console, I have a new series 2 4 speed transmission that I would like to install, will the series one console work with this transmission. Which inner boot do I use with the above setup.Can I use my original early outer boot.
I am wrestling with that myself right now. There are a couple of threads on the site here that address it. Looks like one option is to get a shift lever from a Datsun truck, cut the upper part from the pivot point, weld it on at about 90 degrees and then bend the lever so it sticks up in the middle of the shifter hole. Then you can use the original inner boot and early outer boot.
I think I will just rebuild the series one 4 speed transmission, since I am doing a complete restoration and would like the car to be as original as possible.
What is the value of a series 2 4 speed that was rebuilt?
