Posted January 31, 201114 yr comment_343982 Hi, so I have a question regarding a new fuel filter. When I bought my car it came with an l28 but retained the flattop carbs from the 1973 year my car was made (1973 240z). Which fuel filter will it need? I've read that a 280z would use the fram g3359, but since mine retained the carbs, is it more probable that the original type fuel filter was retained and I should get the fram g4143? thanks! Link to comment https://www.classiczcars.com/forums/topic/38426-fuel-filter-g4143-or-g3359/ Share on other sites More sharing options...
January 31, 201114 yr comment_343985 It will need 2 fuel filters, one up by the engine and one inside the electric fuel pump at the back by the tank. The one in the electric pump is a canister type.The one for the 280 is for high pressure, since you still have carbs you don't use the 280z filter. Link to comment https://www.classiczcars.com/forums/topic/38426-fuel-filter-g4143-or-g3359/#findComment-343985 Share on other sites More sharing options...
January 31, 201114 yr Author comment_343991 From what I understand the fuel filter in the engine bay will be the g4143 meant for the 240z, correct? and as for the fuel pump, I thought the 240z came with a mechanical fuel pump? or would that have been switched during the l28 swap? sorry for all the questions, just haven't been able to get that in depth with the car yet. Thank you! Link to comment https://www.classiczcars.com/forums/topic/38426-fuel-filter-g4143-or-g3359/#findComment-343991 Share on other sites More sharing options...
January 31, 201114 yr comment_343992 The '73 had 2 fuel pumps. One mechanical and the other electric. Get under the back and you should see it. Link to comment https://www.classiczcars.com/forums/topic/38426-fuel-filter-g4143-or-g3359/#findComment-343992 Share on other sites More sharing options...
January 31, 201114 yr Author comment_343993 Oh ok. I'll do that as soon as I can. Thanks for all the help! Link to comment https://www.classiczcars.com/forums/topic/38426-fuel-filter-g4143-or-g3359/#findComment-343993 Share on other sites More sharing options...
