Question about leaking brake fluid
TQs30z
My car, early 260z is leaking brake fluid badly. It leaks all of the brake fluid from the reservoir when I top it off two days ago. I notice the leak is from the bottom of the brake booster, but my question is, isn't the brake booster only act as a pressure builder to assist braking? Why brake fluid will leak from the bottom of the brake booster??? Also, is the 260z and 280z brake booster interchangeable? Please advise, thanks.
Ed
Edited by TQs30z
The Master Cylinder piston seal is leaking. That causes it to leak at the interface with the Booster. A rebuild of the MC is in order. While you're at it, purge the fluid lines and rebuild the rear wheel cylinders and front calipers too.
It might be leaking from the base of the plastic reservoir itself and running down the MC to the booster. I had that happen when I replaced my MC, I had to readjust and retighten the clamp at the base of one of the reservoirs.
Is it coming out of the bottom of the booster, the base of the MC where it bolts to the booster, or the bottom of the reservoirs and running down the bottom of the MC to the booster?
If all of the fluid leaks out in two days, I would be surprised that your MC pistons and seals can still develop enough pressure to apply the brakes.
You could have a cracked reservoir also. Do you have two, front and back, or just one?
The car has been parked for like 1 month now, so I'm not sure if it still has brake or not; but I don't think it has since all the brake fluid has leak already. I just check, the brake fluild actually leak from between the MC and the brake booster. So, I guess the fluid is then go down to the brake booster which I thought where it was leaking before. As I recall, there is no seal or gasket on the MC when I connected to the brake booster. What now? remove the 2 bolts and MC, clean it up and rebolt it back to the brake booster?? And bleed the brake again? Any brake bleeder you guys can recommend??? Those one man job brake bleeder. Please advise, thanks.
Ed
  • Who's Online   1 Member, 0 Anonymous, 241 Guests (See full list)
