Center console and turn signal question
StephenJ
Have purchased a fairly nice 76 280z. There are a couple of items that I am working on and thought I would ask the group here:
1: Would a center console from a 77/78 work fine (without mods) in a 76?
2: Turn signal auto return does not work when turning left or right. Without digging into it yet, is there a general fix? I'm guessing I will have to dig into it to find out.
  • 1 month later...
If your peg is still there, crack open the switch housing that is held on the inside of the blinker switch by two screws. Inside is the extremely simple mechanism that clicks your blinkers off.
Make sure the spring inside is not damaged. If it is not, clean it up and put a little light grease (lithium grease or the like) on the plastic bits inside. This has worked for me in the past.
