Have purchased a fairly nice 76 280z. There are a couple of items that I am working on and thought I would ask the group here:
1: Would a center console from a 77/78 work fine (without mods) in a 76?
2: Turn signal auto return does not work when turning left or right. Without digging into it yet, is there a general fix? I'm guessing I will have to dig into it to find out.
Thanks. That opens up my options on the center console. Every where I have been looking seems to point that they are no compatible. I imagine that it is not restore "correct" for the year. Thanks again!
If it's an original steering wheel, the peg on the back of the hub may be broken off.
If it's a replacement steering wheel, the peg may not have been put in.
Aside from that, check the gates and see if they pivot freely.
E
  • 1 month later...
If your peg is still there, crack open the switch housing that is held on the inside of the blinker switch by two screws. Inside is the extremely simple mechanism that clicks your blinkers off.
Make sure the spring inside is not damaged. If it is not, clean it up and put a little light grease (lithium grease or the like) on the plastic bits inside. This has worked for me in the past.
