Lower Radiator Hose
akzbob
I'm getting ready to replace my lower radiator hose and when I was checking where it ran to, I came across this part which I had not noticed before. I've attached a picture so that you may see what I'm asking about. It appears to be a valve of some sort, but nothing is attached to it. I've looked in the FSM, but it doesn't mention anything. What is it and should it be connected to something? My car has been running fine and will probably bypass it unless someone says otherwise.
Thanks for any help!
1978 280Z
