Posted February 8, 201114 yr comment_345124 Hi all, I am currently having an engine made for me in England for my 260Z. It will hit around 230bhp on the engine, and Im guessing around 190 at the rear wheels. I currently have the standard MSA header:http://farm5.static.flickr.com/4041/4350155683_84587db201.jpgWill this suffice for the new engine? If I upgrade to a better header, will it improve overall?RegardsHendrik Link to comment https://www.classiczcars.com/forums/topic/38518-new-engine-good-header/ Share on other sites More sharing options...
February 9, 201114 yr comment_345170 H3Efficient exhaust flow can increase HP but only in incremental amounts. Don't expect a neck snapping performance change though. The one important aspect of exhaust manifolds is that they last and don't rust out or seize up on the mounting studs Link to comment https://www.classiczcars.com/forums/topic/38518-new-engine-good-header/#findComment-345170 Share on other sites More sharing options...
February 10, 201114 yr Author comment_345332 esmit208 said: H3Efficient exhaust flow can increase HP but only in incremental amounts. Don't expect a neck snapping performance change though. The one important aspect of exhaust manifolds is that they last and don't rust out or seize up on the mounting studsAllright, thx for the info. I´ll see what th dyno says, and then decide what to do Link to comment https://www.classiczcars.com/forums/topic/38518-new-engine-good-header/#findComment-345332 Share on other sites More sharing options...
February 10, 201114 yr comment_345352 Hendrik, who is building that engine for you? Link to comment https://www.classiczcars.com/forums/topic/38518-new-engine-good-header/#findComment-345352 Share on other sites More sharing options...
February 10, 201114 yr Author comment_345359 ChrisZ said: Hendrik, who is building that engine for you? Chris Its Duncan from the Z farm, located in North Yorkshire, a good english friend of mine went to see him. I haven´t actually seen the workplace, but I have full confidence. If you want more details, send me a pm or mail Link to comment https://www.classiczcars.com/forums/topic/38518-new-engine-good-header/#findComment-345359 Share on other sites More sharing options...
