Posted February 12, 201114 yr comment_345536 Looking for a source of inner panel sills. Does anyone have a source for these? Link to comment https://www.classiczcars.com/forums/topic/38556-inner-panel-sill-replacements/ Share on other sites More sharing options...
February 12, 201114 yr comment_345540 Not sure what you're talking about. Would love to help you out. Link to comment https://www.classiczcars.com/forums/topic/38556-inner-panel-sill-replacements/#findComment-345540 Share on other sites More sharing options...
February 12, 201114 yr Author comment_345541 In the picture I have attached, it is the point where the floorpans attach. Link to comment https://www.classiczcars.com/forums/topic/38556-inner-panel-sill-replacements/#findComment-345541 Share on other sites More sharing options...
February 12, 201114 yr comment_345543 If you are talking about the steel just below the holes in the picture you might have to have that fabricated. If you are talking about the finishers that cover those up, they are available from courtesyparts.com for around 30 bucks.John Link to comment https://www.classiczcars.com/forums/topic/38556-inner-panel-sill-replacements/#findComment-345543 Share on other sites More sharing options...
February 12, 201114 yr comment_345544 Those are called rocker panels and only the outer ones are available. You can get them at Tabco http://www.tabcobodyparts.com/html/table_of_contents.htm -Mike Link to comment https://www.classiczcars.com/forums/topic/38556-inner-panel-sill-replacements/#findComment-345544 Share on other sites More sharing options...
February 12, 201114 yr comment_345553 I just found your other thread about your floors http://www.classiczcars.com/forums/showthread.php?threadid=41232. You should have just added to that one rather than start a new thread looking for parts. Maybe an Arne or another admin can combine these into just one thread.-Mike Link to comment https://www.classiczcars.com/forums/topic/38556-inner-panel-sill-replacements/#findComment-345553 Share on other sites More sharing options...
February 12, 201114 yr comment_345556 Just a heads up. When you call Tabco to order the price will be higher. He says he hasnt updated his online pricing since 2003. Link to comment https://www.classiczcars.com/forums/topic/38556-inner-panel-sill-replacements/#findComment-345556 Share on other sites More sharing options...
