Posted February 12, 201114 yr comment_345565 the main fuel line in the tank has a leak so if you let the gas drop under the gas line it gets air in line Link to comment https://www.classiczcars.com/forums/topic/38559-i-need-help-finding-cheap-new-gas-tank/ Share on other sites More sharing options...
February 12, 201114 yr comment_345566 You should mention what year/model car you are needing a tank for. They are not all the same. If it is just a leak I am sure you could remove the tank and get it repaired.-Mike Link to comment https://www.classiczcars.com/forums/topic/38559-i-need-help-finding-cheap-new-gas-tank/#findComment-345566 Share on other sites More sharing options...
February 12, 201114 yr comment_345587 You might want to check out www.zpartswarehouse.com. I just bought a few items from them. They have a massive supply of 240z - 28zx parts. So far they have had everything part I have asked for. Link to comment https://www.classiczcars.com/forums/topic/38559-i-need-help-finding-cheap-new-gas-tank/#findComment-345587 Share on other sites More sharing options...
February 13, 201114 yr comment_345740 Buddy, that happened to my '75 long ago. It's pretty baffling to run out of gas when the tank is half full!You don't need a new tank, though. Just take your tank to a good radiator shop. They'll be able to repair it fairly economically. Link to comment https://www.classiczcars.com/forums/topic/38559-i-need-help-finding-cheap-new-gas-tank/#findComment-345740 Share on other sites More sharing options...
