Posted February 14, 201114 yr comment_345847 Hi Guys. I'm not sure if I'm posting in the right spot. If not, please excuse my being a knucklehead noob. I have a pair of Euro/JDM tail lights that I want to post to the classified section, but I can't figure out how to do it. Any help would be appreciated. Cheers, Scott Link to comment https://www.classiczcars.com/forums/topic/38589-classified-posting-question/ Share on other sites More sharing options...
February 14, 201114 yr comment_345856 OK the classifieds have their own site this happened less than a year a go.You can access this site from the drop downs but to save time use this linkhttp://www.datsunclassifieds.com/index.php From hear log in your password and user name is the same as this sight.Next click on place adthen fallow the three steps.If you plan to post pictures just put one in and go back and edit the ad to put more in otherwise you have problems Link to comment https://www.classiczcars.com/forums/topic/38589-classified-posting-question/#findComment-345856 Share on other sites More sharing options...
February 14, 201114 yr Author comment_345952 Thank you very much, Sir... Cheers, Scott Link to comment https://www.classiczcars.com/forums/topic/38589-classified-posting-question/#findComment-345952 Share on other sites More sharing options...
February 14, 201114 yr comment_345970 I saw your post. I'm glad that worked Link to comment https://www.classiczcars.com/forums/topic/38589-classified-posting-question/#findComment-345970 Share on other sites More sharing options...
February 15, 201114 yr comment_346026 Yep, and if you aren't already logged in when you go to that site, simply use the login link with your same user account info from this site. After you login, you'll see a link called "Place an Ad"... And, it should be downhill from there. Let me know if you have any troubles.Mike Link to comment https://www.classiczcars.com/forums/topic/38589-classified-posting-question/#findComment-346026 Share on other sites More sharing options...
