Hi, so my starter is dead. RIP. It clicks once and silence. So I had a question regarding replacement. My car came with an automatic, which it still has now, but I am eventually going to change it to manual. But I need to replace the starter ASAP. So, I need an AT starter no matter what for right now, but will it work once I change to manual? or will I need to get the MT starter later? Just trying to judge how much I should spend on the starter. and if this did come up, I did use the search button and google. Thanks!
Those both appear to be gear reductions starters. The gear reduction starter actually became standard on the 78 280Z and 810 and continued through the 83 280ZX and 84 RWD Maxima.
so based on what you are saying:
http://cgi.ebay.com/ebaymotors/78-DATSUN-NISSAN-280Z-MANUAL-STARTER-/380314047585?pt=Motors_Car_Truck_Parts_Accessories&hash=item588c7bd461#ht_500wt_749
This should be the gear reduction starter since it is off a 78 280z? and should I get a new reman starter or a used good one like this work?
Oh, and thank you for the help!
