Posted February 19, 201114 yr comment_346590 i've looked and can't find it. i've seen it somewhere. do i take the six marked bolts off the flywheel to get it off ? have to be ready to grab it, i do know that. thanks timsz Link to comment https://www.classiczcars.com/forums/topic/38641-71-240z-flywheel-removal/ Share on other sites More sharing options...
February 20, 201114 yr comment_346619 Yep, gotta take those bolts out. An air impact gun or ratchet is essential unless you have a really secure method of locking the flywheel in position. Cranking with a conventional ratchet will just turn the flywheel. I have done it both ways, and air is the way to go. Link to comment https://www.classiczcars.com/forums/topic/38641-71-240z-flywheel-removal/#findComment-346619 Share on other sites More sharing options...
February 20, 201114 yr comment_346632 If you have no air tools, you can fab up a strap of some sort, that bolts one end to a clutch cover hole, and the other to the engine block. That will keep the crank from turning while you break the bolts free. You can also use it to hold it while you torque down the bolts when you replace it later. Link to comment https://www.classiczcars.com/forums/topic/38641-71-240z-flywheel-removal/#findComment-346632 Share on other sites More sharing options...
February 20, 201114 yr Author comment_346633 thanks so much. yes i do have air and will use it . timsz Link to comment https://www.classiczcars.com/forums/topic/38641-71-240z-flywheel-removal/#findComment-346633 Share on other sites More sharing options...
February 20, 201114 yr comment_346638 The flywheel probably won't just fall off, in fact, you might even have to give it a gentle tap. It is always best to loosen one of the bolts, then put it back just finger tight snug while taking the others out just in case. Link to comment https://www.classiczcars.com/forums/topic/38641-71-240z-flywheel-removal/#findComment-346638 Share on other sites More sharing options...
February 20, 201114 yr comment_346650 My solution was always to just wedge a big flat blade screwdriver with the handle on the framerail and the blade on one of the flywheel teeth. I didn't have any air tools at the time.IdahoKidd is right too, it shouldn't just fall right off because there's a small ridge on the flywheel that fits over the back of the crank. Be ready though, just in case. Link to comment https://www.classiczcars.com/forums/topic/38641-71-240z-flywheel-removal/#findComment-346650 Share on other sites More sharing options...
