March 2, 201114 yr Author comment_347976 Good Day Adrian I am starting with a 280 Z shell as I believe it stronger and I have no problem withengine and drive train. To get propper struts and springs is where I need help. Also the propper look (fender flares, Light pods on the hood). Any help is much wanted.Ken Edited March 2, 201114 yr by Gp4VioletGTS Link to comment https://www.classiczcars.com/forums/topic/38672-working-on-zs-for-40-years/?&page=2#findComment-347976 Share on other sites More sharing options...
March 2, 201114 yr comment_348001 Gp4VioletGTS said: Good Day Adrian I am starting with a 280 Z shell as I believe it stronger and I have no problem withengine and drive train. To get propper struts and springs is where I need help. Also the propper look (fender flares, Light pods on the hood). Any help is much wanted.KenAre yoe allowed to use fender flares ? and what does the regulations says ?Suspension wise there is a lot to do for historic rally and verry profesional stuff. Link to comment https://www.classiczcars.com/forums/topic/38672-working-on-zs-for-40-years/?&page=2#findComment-348001 Share on other sites More sharing options...
March 3, 201114 yr Author comment_348090 Historic rallying in the US has no strick regulations. You inter your car in your NationalClass and then if it is an old car you put an H after yours number plate and you are inthe Historic class. There are no Historic Stage Rallies. I can try to change this as I haveogranized some rally sprints and rally crosses. Even if I just start off with a few cars. I can get 6 -8 cars from just my friends. So fender flares are not a problem but I would still like to use the right ones. Do you have any photos and specs on the suspension.Like spring rate, travel, Strut shaft size. Ken Edited March 3, 201114 yr by Gp4VioletGTS Link to comment https://www.classiczcars.com/forums/topic/38672-working-on-zs-for-40-years/?&page=2#findComment-348090 Share on other sites More sharing options...
