Not much power
T-stone
set up- 1972 240z l24 block N47 head, schneider cam Intake Valve Lift 48
Exhaust Valve Lift 480 duration 274
header 6-1 2.5 inch outlet
aluminum 3 row radiator, stock dizy new points, condensor balest resistor, rotor butten, new dis cap.
ngk copper plugs, ngk plug wires.
stock coil.
timing set good, point gap set 16, carbs balanced and tuned.
Took the car to my uncles house, he has had many 240's some stock and others built.
Let him drive ther car, he says it has about half the power of what it should, i have just now got the car relable, it has had manny problems in the past.
the car runs good and sounds strong, but feels like it is lacking power.
droping the clutch from about 5 grand from first to second i get a little bark, fulles steady through all gears and off take off.
ran a compression test, 1-6 cylinders were at 90psi across the board.
i was looking up compression numbers, it was said they should be anywhere from 160 and up.
not so how accuret this is?
is this what i should excpect from the motor or am i really lacking in power?
Disconnect the coil wire
ignition switch off
(Wide Open Throttle) Throttle open (Butterflies open) Carb Piston propped up so everything can breathe, thru the carb and butterflies)
remove only the spark plug of the cylinder that you're testing, leave the others in.
Spray some WD-40 down into the cylinder, thru the spark plug hole.
Attach the compression tester, zero out the gauge.
Use a starter motor jumper to engage the motor for about 3 seconds.
write down your results, test again, write it down, then move on to the next cylinder after reinstalling the spark plug of the cylinder you just tested
This is the way I tested mine, worked great. if anyone here sees something wrong in my instructions, PLEASE advise before he actually does the test.
Dave
I am not sure how much overlap the cam has but a performance cam with lots of overlap will have lower cranking compression, but probably not as low as 90psi. The other thing that can affect cranking compression is cam timing. Just some things to think about
Bob
I did not opent the threttle while doing the compression test, dint even cross my mind to do that.
I will run test as recomended tomorrow and update.
Im a little iffy on the cam timing, i am running the stock cam gear, numbers on the gear run from 1-3 i have mine set on 2.
i have heard that each mark advances or retards by about 4 degrees, im not sure if i have mine set to how it should.
i looked up videos and pictures to try and find the correct way to set, even the old service manual was mum on this.
  • Who's Online   0 Members, 0 Anonymous, 269 Guests (See full list)
