still trying to get spark. if plugs are not in correct order will engine not spark?
when we were looking for TDC we may have not been on  a compression stroke .  there for the rotor was pointing to wrong spot for #1 plug on dizzy. if we were not on compression stoke, would it be the exact opposite from where rotor was pointing?? or we have to look for tdc with compression stoke again?
also - can the #1 spot for plug be anywhere on the  distributor? or is it always supposed to be the same spot? to the right of clip.
any chance  the oilpump rod was inserted wrong?
also - could it be a bad pickup?? anyway to check the  pickup?? does gap need to be correct for spark?
also - is 280z pickup same as 260z pickup?
will the photo of the 280 pick up work in 260?
Edited by Shawninvancouver
