Email logins are now active ×
Thermostat Kit Part Number
Zealous
Hey All,
I searched around here and could not find this information. There are a lot of threads referencing thermostat but not the part numbers.
I am looking for the Nissan Part number for the Thermostat Kit. I have checked both the CD and the online catalogue at http://www.carpartsmanual.com/datsuns30/DatsunFairladyZIndex/tabid/1543/Default.aspx
But I cannot find the kit that comes with all the gaskets just the individual parts. I know courtesy Nissan sells the kit but I am ordering from NissanParts.cc as they have some other great deals on parts and do not want to pay for two sets of shipping. Anyone know the p/n for the kit?
Also I know there are different temperature thermostats, how do you differentiate the two?
Wouldn't you know it just after I post this, I finally find the part number online by searching high res photos.
Here it is for future reference to all: 21200-P7991
Mods if this is a waste of time feel free to delete.
That's a 180 degree thermostat. But I think that should read 21200-P7901. I don't know how to differentiate them by number I just know that is the number for a 180. 21200-F3160 is a 160 degree, 21200-P7901 is 180 degree, and 21200-P7906 is 190 degree.
Edited by sblake01
When I changed my thermostat last summer I was surprised with the amount of corrosion on the bolts (one of them snapped - that's always fun). In the end I decided to replace the bolts and housing. I would strongly recommend that you use your favorite bolt-loosener liquid (I use ATF & acetone) before removing the bolt and never-seize on reassembly.
Phew, I was worried I had got the part number wrong. Yeah I looked at just the thermostats and it is about the same price with the gaskets so I decided I should try and get the gasket.
Thanks Gary, that is good advice. Ill probably replace anything that needs doing, I am replacing the thermostat for when I replace the radiator may as well do preventative maintenance before I take the car to the track again.
  • Who's Online   1 Member, 0 Anonymous, 375 Guests (See full list)
