Posted August 4, 200024 yr comment_805 Hi.I just had a pair of grose jets delivered to my door from Victoria British...I am putting them in my 73 Z with 72 carbs....problem is there are NO instrucrtions...one is marked long, the other short...I can't see or measure a differance (with micrometer)...I have Scott's video and it only makes passing referance to it....help..... I put the short in the rear carb, the one with the shorter tang on the float bowl cover...I used the supplied various fiber washers to set the grose jet as close to the original height below the cover as the original and then bent the float tang to get 00.55 inches to fuel shut off.........its still weeks before the carbs go back on the car...did I do it right or should I tear ity all apart to do it differantly???RSVP..Thanks in advance Tim BrownWinnipeg (the great frozen North)Canada------------------ Link to comment https://www.classiczcars.com/forums/topic/388-grose-jets/ Share on other sites More sharing options...
August 10, 200024 yr comment_806 Whoa!! Both needles should be the same. I'm suspicious about those needles. If you want a good resource for needles (and someone who knows what they are talking about) then call Les or Dennis at Classicdatsun. http://classicdatsun.com [m]------------------Mike Gholson1971 240z, Mikuni Carbs, Tokico 5-way Adjustable Struts, Ferarri Yellow, Stock Engine, 15x9 wheels w/50 series Falken tires, Currently being restored.[This message has been edited by Mike (edited 08-10-2000).] Link to comment https://www.classiczcars.com/forums/topic/388-grose-jets/#findComment-806 Share on other sites More sharing options...
March 15, 200124 yr comment_807 My Z is similar to your 73` with 72 carbs. If you can, check out my rebuild carb question. Regards, MikeT73. Link to comment https://www.classiczcars.com/forums/topic/388-grose-jets/#findComment-807 Share on other sites More sharing options...
March 19, 200124 yr comment_808 Hey Tim: I bought a set from ZTherapy.com & they are both the same, but Scott sent instructions and some washers to use one a a short. Try to contact Scott and ask him for sure, but I seem to rember tha the short went on the rear carb. I'll try to find the instructions to confirm (if I still have them.)------------------Carl Stahlnecker72 240Z "Bambikiller"cstahlnecker@hotmail.combambikiller240@altavista.com Link to comment https://www.classiczcars.com/forums/topic/388-grose-jets/#findComment-808 Share on other sites More sharing options...
