Posted March 7, 201114 yr comment_348518 Just finished installing new rear struts and bushings. I'm looking at painting the rear brake drums and am wondering if I should use high temp paint or just a good rust preventative spray paint? I know that the brakes can get hot, but is it hot enough to cause regular spray paint burn?Thanks for any help.1978 280Z coupe. Link to comment https://www.classiczcars.com/forums/topic/38815-brake-drums/ Share on other sites More sharing options...
March 7, 201114 yr comment_348526 Just finished installing new rear struts and bushings. I'm looking at painting the rear brake drums and am wondering if I should use high temp paint or just a good rust preventative spray paint? I know that the brakes can get hot, but is it hot enough to cause regular spray paint burn?Thanks for any help.1978 280Z coupe.They definitely get hot enough to damage regular paint... I would use some of the Rustoleum high heat paint or even some of the "BBQ Black" paint. Even these will not be permanent, but will work well. Be prepared for a little bit of "burning paint" smell regardless... Link to comment https://www.classiczcars.com/forums/topic/38815-brake-drums/#findComment-348526 Share on other sites More sharing options...
March 8, 201114 yr comment_348539 I had a set powder coated. You may want to use a zinc chromate primer for aluminum drums. Link to comment https://www.classiczcars.com/forums/topic/38815-brake-drums/#findComment-348539 Share on other sites More sharing options...
August 13, 201113 yr comment_363972 Why not try some VHT satin clear header paint. Does not dry glossy and protects up to a high degree. Link to comment https://www.classiczcars.com/forums/topic/38815-brake-drums/#findComment-363972 Share on other sites More sharing options...
August 14, 201113 yr comment_364020 Why paint them? Fashion/style? It can make the heat dissipation worse. Although for drums on the rear this might not be an issue. Link to comment https://www.classiczcars.com/forums/topic/38815-brake-drums/#findComment-364020 Share on other sites More sharing options...
August 14, 201113 yr comment_364051 I would consider just buffing them up with some metal polish. Link to comment https://www.classiczcars.com/forums/topic/38815-brake-drums/#findComment-364051 Share on other sites More sharing options...
August 15, 201113 yr comment_364102 When the time comes, mine will be bead blasted.Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/38815-brake-drums/#findComment-364102 Share on other sites More sharing options...
