Mike Posted December 20, 2002 Share #25 Posted December 20, 2002 Originally posted by BambiKiller240 When I double-click on the INSTALL button, nothing happens. Also, I don't see the UNPACK.BAT or SETUPREG.EXE files. Can anyone tell me where I'm going wrong here? I think you are missing the other RAR files because some of your stuff is missing. A RAR archive can be split up into many smaller files. So, instead of one large archive, it's many. A split RAR archive will have a parent file with a .RAR and children files with .R00 .R01 .R02, etc. Problem with RAR is that you can download part of the archive and it will attempt to uncompress. It should fail and give you an error, but, it doesn't. Anyway, the install.zip file should be unzipped into the same folder as all of the .RAR files. When that's done, just double click the INSTALL.EXE. When you do this, you'll see a VISPeR Installer appear in your task bar. Wait for a long time (around 30-sec to a minute) and it will appear. Link to comment Share on other sites More sharing options...
Bambikiller240 Posted December 20, 2002 Share #26 Posted December 20, 2002 The VISPeR Installer does appear. That's where I'm clicking on the INSTALL button. But nothing happens when I click that button.The files that appeared when I did the UNZIP are:BASS.DLL 90.4 kbFILE_ID 1018 bytesVSP INSTALL 291 kblegoland (GIF) 14.1 kbUNRAR.DLL 52.0 kbVSP 539 kbVISPER (doc) 10.6 kbINSTALL (setup info) 360 bytesBTW, they unzipped into their own folder WITHIN the original folder that I created to download the 4 files from the Net.What seemed weird to me was when downloading the zipped "install" file from Angelfire it was only 444kb in size where the other 3 files were over TWO MEGS each.Anyway, I'm not much of a gamer anyway. Probably not worth either of our time to mess with this anymore. But I do appreciate your time to try to help me with this Mike!Thank youCarl Link to comment Share on other sites More sharing options...
Mike Posted December 20, 2002 Share #27 Posted December 20, 2002 One more quick point... if you read my last message, note that all of the RAR files need to be in the same directory as the install files (after they are unzipped). Try this and I'm sure it will work for you. Link to comment Share on other sites More sharing options...
